Test Point Location Generator
Generate test points and extract location and data from designs.
Depending on the routing structure, this software provides versatile functions to generate test point locations. This software can load a netlist used and modified in manufacturing sites and compare them with the original design data. Test-Point Location Generator is in the Manufacturer menu in PollEx PCB.
