View
  • View: Set window display.
  • Draw Mouse Cross Line: Mouse pointer shows with + mark.
  • Foreground Selected Route: During picking operation, selected pattern will be shown at the top if there are multiple patterns are overlapped.
  • Hatched Display: Display polygons to hatch as Forward Diagonal / Backward Diagonal / Cross / Diamond / Vertical /Horizontal.
  • Auto Zoom: Upon using PCB Explorer, Highlight or Exclude operation shows objects with auto zoom-in.
  • Fill Selected Route: Show selected routing pattern with filled shape.
  • Zoom to Mouse Point Area: Zoom area based on mouse point.
  • Board Origin Mark: Display the board origin mark.
  • Grid: Set the distance of grid and decide whether PollEx PCB shows grid or not.
  • Set Capture Window: Use the menu to make partial image capture, screen capture, full area capture.
  • Zoom: Specify the zoom ratio.
  • Measurement
    • Dimension Text Scale: Set the dimension’s size using measure function.
    • Decimal Point: Set the decimal point for measure resulting. Select the value 1~5.
    • Display: Select one among ceiling, round and floor for the decimal point.
  • Net Color Display: If source ECAD file has its original color settings for routing nets, this option will decide whether PollEx PCB show original ECAD color or use default PollEx PCB color.
  • User Windows Operation: For zoom In/Out and panning operation, operations will be applied reversely.
