Allegro Interface
Display and define the initial view status for Allegro.
- In the Environment dialog, click .
Default Read Type: Define the default color settings for 3D package.
- Read from a binary file: Define the default type of Allegro data as binary.
- Read from an ASCII file: Define the default type of allegro data as ASCII.
Binary File Reading Options: Define options for importing binary data.
- Executable directory: Define the path of command which extract ASCII data from binary file.
- Control file path: Define the configuration file for importing Allegro data.
- Part MPN: Define the property for assigning MPN to part.
Library-Layer Setup: Define layer matching table from Allegro to PollEx.
- Solder Resist Top: Define the top side solder resist layer.
- Solder Resist Bottom: Define the bottom side solder resist layer.
- Silk top: Define the top side silkscreen layer.
- Silk Bottom: Define the bottom side silkscreen layer.
- Metal Mask Top: Define the top side metal mask layer.
- Metal Mask Bottom: Define the bottom side metal mask layer.
- Add Hole: If needed, define added hole layer.
