Input Setup
DFE Input
- DFE Input: Use for making DFE input file.
- Dialog sections: Classification, Check Item Category, Input mode change, and action
- Classification subsections: Component Group Type classification, Net Group Type classification, Circuit Group Type classification, and via coverage.
- Result: Use for reviewing DFE result.
- Core Running: Execute DFE running based on input file, *.dfesi.
- DFE Environment: Use for setting DFE running environments.
Most of DFE rule checking needs classifications, target nets, target components and target circuits. The classified nets, components and circuits are used as target objects in electrical rule checking.
