Impedance
This item analyzes and checks single-ended and differential impedance of target nets.
- Check the single-ended impedance.
- Check the differential impedance (Characteristic, Zdiff,
Zcommon).
Figure 1. - Item: Enter sub item name. User can enter arbitrary name.
- Net Group: Select target net groups to be tested. Allow multiple net groups.
- Target Impedance: You can assign required impedance for main area and break
in/out area.
Figure 2. Break-In/Out Definition - Options: You can assign PIN/VIA Escape length and other options.
- Pin Escape: Enter a radius of circular region around pins to be excluded for the rule check.
- Via Escape: Enter a radius of circular region around vias to be excluded for the rule check.
- Ignore trace shorter than: the trace shorter than this length will be ignored.
- Ideal: Consider the reference plane as ideal plane during analysis.
- Real: Analysis proceed by reflecting the shape of the reference plane.
