Bonding Area
Check FPCB bonding areas.
- Bonding Layer Definition: Define FPCB bonding area with layer selection.
- Layer Selection: Select layer containing bonding area from layer list.
- Checking
- Clearance between Bonding Areas: To check clearance between bonding areas, set the clearance value for them.
- Keep-out from Bonding Area: Check whether Via or hole is placed in
bonding area.
Figure 1.- Via: Check Via existence in bonding area.
- Keep-out Expand: To expand bonding area, users can assign expanding distance.
- Hole: Check hole’s existence in bonding area.
