Data Existence
Verify the certain layers existence and data existence on the layer.
- Layer & Data Existence Checking: Check data existence out of the board
outline.
- Check Objects are placed on Specifying Layer: Specify the layer that target components are placed on from the artwork layer list of active design.
- Layer Existence: Check if layers exist for layers defined in the above section.
- Checking for Objects out of Boundary: Check data existence out of given
layers boundary.
- Boundary Layer: Specify the layer from the artwork layer list.
- Layers Definition for Target Objects are placed: Select layer from the artwork layer lists for objects out of layers defined in the above section.
- Exclude Checking for Components: Specify the void-checking component group from the predefined component group.
- Exclude Checking for Specified Character String: Define the void-checking text strings using the Following Text Filter tool.
