Ref Name Silk
Check the existence of a reference name on the silk layer.
- Target Component Placed Layer Definition: Select layer(s) where the reference name should be.
- Option
- Detect multiple Reference Name on Same Layer: Check if there are multiple reference name silkscreens on the same layer.
- Component Selection and Checking
- All Component: Check for all components on the design.
- Exceptional Component: Define the void-checking components for All Components case.
- Both: Check if the Reference name exists on both top and bottom layers.
- Same: Check if the Reference name exists on the same layer as the component placed layer.
- Mirrored: In the Top Layer Ref Silk, mirrored text fails.In the Bottom Layer Ref Silk, non-mirrored text fails.
- For Component Groups: Use this menu to check for certain component
groups.
- Item: Specify item name.
- Component Group: Select target component group from group list.
- Both: Check if the Reference name exists for both top and bottom layers.
- Remainders: For undefined components in table, you can check the existence of reference name.
