Interactive Rendering
The Interactive rendering modes are display modes that render your scene in real time, so you can interactively apply materials, modify the environment, and change the camera position.
- The Interactive Rendering mode icons are in the bottom left of each modeling view near
the other display mode icons.
- You cannot create, modify, or delete objects (including lights) during interactive rendering mode. To perform these tasks, exit interactive rendering and return to modeling.
| To | Do this | Note |
| Start interactive rendering |
The scene will transform from grainy to clear based on the speed of your computer. |
| Pause or resume interactive rendering (Presto only) |
The flashing icon indicates that interactive rendering is paused. |
| Exit interactive rendering | Click another display mode icon:
Exit interactive rendering to return to creating, modifying, or deleting objects (including lights). |
| Change the Presto interactive rendering settings |
Presto GPU support for macOS 10.14 (Mojave) and above is unavailable due to driver incompatibility. In this case, CPU is used. |
| Reset internal cache | While holding down Ctrl, right-click the
Interactive Rendering modes icon. |
