2022.3
Create an analysis for your project.
View new features for SimSolid 2022.3.
Discover SimSolid functionality with interactive tutorials.
Interfaces that support SimSolid output file format.
Information about treatment and properties of geometric entities in SimSolid.
Summary of available functionality for defining the properties and behavior of parts in the model.
Connections are used to define the association of different regions of interest between parts in an assembly.
Modal analysis evaluates the frequencies and corresponding modes of vibration of your model.
Evaluate your design in real-time using SimSolid dynamics analysis.
Thermal analysis predicts how thermal effects propagate through the model. Steady state and thermal transient analyses are supported.
Fatigue analysis is intended for predicting life of structures under cyclic loading.
Boundary Conditions available for SimSolid.
Run analyses and view a variety of results in SimSolid.
Design studies allow you to quickly evaluate and compare the structural performance from different design scenarios.
Solved verification models.
ON THIS PAGE
