The Spray Coating model adds the mass of one type of particle to another upon contact. When the spray material contacts another type of material, the spray material’s volume is added to the target material and the spray particle is deleted.
Spray particles do not impart a force on either geometry or any other particles. This means that you can run the simulation with the appropriate time step for the target material. EDEM will automatically calculate the time step for the smallest particles (the spray particles). So to avoid running at a time-step that is unnecessarily small, you can manually define the time step based on the target material’s size and properties. This can be done using the following equation, where TR is the Rayleigh time-step, R is the particle’s radius, ρ its density, G the shear modulus and v the Poisson’s ratio.
| (1) |
Create at least two material types, one being the target material and the other being the spray material. The spray material should be significantly smaller than the target material. Single spheres should be used for the spray material as the shape will have no effect on the simulation results. Most material properties of the spray particle will also have no effect on the result, only the particle volume, density and radius will have an effect.
(c) 2022 Altair Engineering Inc. All Rights Reserved. |
