After running a simulation, view the plotted result data that is defined in the scope
blocks.
A plot is generated for each scope block in the
model.
To open a scope window, do one of the following:
- From your model, double-click a scope block.
![](../../images/math_solutions/model_scope_name.png)
- From the Project Browser, double-click a scope block name:
![](../../images/math_solutions/project_browser_plot.png)
The scope window opens and displays the plotted results from the
selected scope block.
![](../../images/math_solutions/scope_plot.png)
Click OK.
To view the help page that explains all the parameters for
a scope block, select the block in your model, then press
F1.
