Premium Access to AMDC allows you to leverage advanced search using multiple search criteria, compare materials, and
view curve data. You can also download CAE material data in the required units to your workstation.
Launch the application to access the Altair material data. You can customize and launch the application from Favorite
Apps, on the Altair One Home page.
View information such as material name, quality, type, provider, version, chemical composition of a material, material
test information, and detailed material properties.
The material properties data such as Fatigue Properties, Mechanical Properties is displayed. The tested data for these
properties is also displayed as supplied by the provider.
Many materials have multi point data associated with them (For example, stress-strain data or PVT data for molding
applications). Such data can be viewed as a plots in AMDC.
Advanced Search allows you to build a search query by combining multiple search criteria. Use filters to find properties
and define value ranges. You can also add filters such as availability of plots, certifications or regional availability
to quickly find relevant materials.
composition of a material, material test information, and detailed material properties.
Choose one of the following:
Double-click the material.
Hover over a material, click
A window opens to the right. You can resize the right pane using your
cursor.
Note: Click to view the material information in a full
screen mode.
By default, the Info tab displays the general
information of the selected material.Figure 1. Info Panel
