Compose-1100: The Compose Debugger
Tutorial Compose-1000 introduced basic operations to create, edit, and run a simple OML script in Compose. Compose-1100 introduces the debugger.
Launch Compose
This launches Compose. Notice that by default, a file named Untitled1.oml exists in the Editor window.
By default, the application is in Authoring Mode, where scripts can be edited and executed interactively.
Start the Debugging Mode
Add a Breakpoint and Start Debugging the File.
Inspect Variable Values Using the Editor and Watch Windows
Enter a Function and Investigate the Call Stack Window
Investigate Variables in a Function Using the Variable Browser and Watch Window.
Use the Step Until Option on the Debug Toolbar
Add a Condition to the Breakpoint
Add Another Breakpoint, Enter the Function zoo, and Observe the Call Stack Window.
Stop Debugging and Exit the Debugging Mode
From the debugging toolbar, click Stop Debugging,
, to stop the current execution.
Press the debug icon,
, to exit the Debugging Mode.
- This returns the Compose GUI to the Authoring Mode. At this point, you can continue with any authoring mode activities.
