Interactive Usage
While scripts are running, you may still view and manipulate scripts and plots, depending on the language used. When an OML script is executed, the application remains active.
- Use the Stop button to stop a long running script (infinite loop).
 - View and manipulate plots (such as zooming in on plots).
 - Navigate the data via the pagination mechanism.
 - Enter values in the Command Window, if interactive commands such asinput are used.
When a Tcl script is executed, the application is waiting for the script to complete.
When a Python script is executed, the application remains active.
 - Enter values in the Command Window, if interactive commands such as input are used.
When an R script is executed, the application remains active.
 - Enter values in the Command Window, if interactive commands such as readline are used
