The Blocks menu lists Embed’s standard blocks. These blocks are also listed in the Blocks and Block Diagram windowpane, along with OpenVision blocks and State Chart blocks. If you have the necessary add-on modules, you will also have access to Embedded blocks, Comm blocks, and Digital Power blocks.
Standard blocks can also be accessed from the Blocks toolbars.
