When you activate View > Data Types and de-activate View > Presentation Mode, the connector tabs on blocks are colored to indicate the types of data (or signals) entering and exiting the blocks. The following table lists all the data types and their corresponding connector tab colors.
Data Type | |
Scaled Integer |
Float |
Double |
Structure |
Matrix COMPLEX |
Matrix double or COMPLEX |
String |
Char |
Short, integer, or enum ComboItem |
Long |
Unsigned char |
Unsigned short |
Unsigned long or void |
Pointer |
Note: For plots, polar plots, meters, and stripCharts, the input connector tabs reflect the color of the signal trace, not the data type.
