Before you can linearize a system, make sure that a Signal Consumer block (for example, a plot block or export block) is directly or indirectly connected to the system to be linearized.
If you have not simulated the diagram containing the system
to be linearized, Embed automatically simulates for one time step before
linearization. To simulate to a specific operating point, use the System menu’s
Go, Stop, and Continue commands, or the corresponding ,
, and
buttons in the toolbar.
