If the diagram contains one or more embedded diagrams, any changes you make to those diagrams are not saved until you use one of the following File > Save Embedded command options:
• Save Embedded Blocks to Source Files: Saves the changes back to the source diagrams.
• Save as a Single Combined File: Saves the changes to the current diagram only. All links between the embedded blocks and the source diagrams are broken.
