Adding a Voltage Source
Add a voltage source to the port of the pin.
- On the Source/Load tab, in the Sources on ports group, click the Voltage source icon.
On the Add voltage source dialog, use the default
settings.
Click Create to define the voltage source and to
close the dialog.
Note: The Configuration tab (in the model tree) was automatically selected when you defined the voltage source. Configuration tab is where the sources, loads and frequency are set.
