Topics Discussed in Example
Before starting this example, check if the topics discussed in this example are relevant to the intended application and experience level.
- CADFEKO
- Create the pin using a cylinder.
- Create the waveguide sections using cuboids.
- Define waveguide ports on each end of the waveguide.
- Add a waveguide source.
- Set the solution frequency.
- Specify local (fine) meshing for the waveguide ports.
- Specify symmetry to save computational resources.
- Specify near fields on a plane inside the waveguide.
- Mesh the model.
- Run CEM validate to ensure the model is electromagnetically validated.
- Run the Solver.
- POSTFEKO
- View the simulated input reflection coefficient on a graph.
- View the instantaneous near field inside the waveguide.
- View an animation of the near fields.
Altair/2022.0/help/feko/examples/GetStarted_models/Project5-Waveguide_Power_Divider/Waveguide_Divider.cfx
