Excitation
Excitation data consist of voltage sources, plane waves, waveguide sources, equivalent sources and Hertzian dipoles.
Voltage Sources on Segments
EXCITATION BY VOLTAGE SOURCE AT A SEGMENT Name: Excitation index: 1 Frequency in Hz: FREQ = 7.49481E+07 Wavelength in m: LAMBDA = 4.00000E+00 Open circuit voltage in V: |U0| = 1.00000E+00 Phase in degrees: ARG(U0) = 0.00 Attached to port: Segment port Port at segment with label: 1 Absolute number of segment: 11 Radius of segment in m: 2.00000E-03 Location of the port in m: x = 0.00000E+00, y = 0.00000E+00, z = 0.00000E+00 Positive direction: x = 0.00000E+00, y = 0.00000E+00, z = 1.00000E+00
Similar information is provided for other voltage sources (such as a voltage source on an edge port and on a microstrip port and a voltage source connected to a general network).
Waveguide Ports and Waveguide Sources
DATA FOR WAVEGUIDE PORTS Waveguide port label: Port Port type: Rectangular Port dimensions Width: 1.29600E-01 m Height: 6.48000E-02 m Port reference points in m: Point S1: x = -2.37927E-01, y = -6.48000E-02, z = -3.24000E-02 Point S2: x = -2.37927E-01, y = 6.48000E-02, z = -3.24000E-02 Direction of propagation: x = 1.00000E+00, y = 0.00000E+00, z = 0.00000E+00
MODE EXPANSION DATA OF A WAVEGUIDE PORT
Frequency: 1.64500E+09 Hz
Mode indices Cutoff freq. Transverse wave impedance Propagation factor Description
m n in Hz real part imag. part real part imag. part
TE 0 1 2.3132E+09 0.0000E+00 3.8105E+02 3.4085E+01 0.0000E+00 Evanescent
TE 0 2 4.6264E+09 0.0000E+00 1.4331E+02 9.0626E+01 0.0000E+00 Evanescent
TE 1 0 1.1566E+09 5.2979E+02 0.0000E+00 0.0000E+00 2.4515E+01 Propagating
TE 1 1 2.5862E+09 0.0000E+00 3.1053E+02 4.1826E+01 0.0000E+00 Evanescent
TE 1 2 4.7688E+09 0.0000E+00 1.3845E+02 9.3812E+01 0.0000E+00 Evanescent
TE 2 0 2.3132E+09 0.0000E+00 3.8105E+02 3.4085E+01 0.0000E+00 Evanescent
TE 2 1 3.2713E+09 0.0000E+00 2.1916E+02 5.9264E+01 0.0000E+00 Evanescent
TE 2 2 5.1725E+09 0.0000E+00 1.2637E+02 1.0277E+02 0.0000E+00 Evanescent
TM 1 1 2.5862E+09 0.0000E+00 4.5703E+02 4.1826E+01 0.0000E+00 Evanescent
TM 1 2 4.7688E+09 0.0000E+00 1.0251E+03 9.3812E+01 0.0000E+00 Evanescent
TM 2 1 3.2713E+09 0.0000E+00 6.4758E+02 5.9264E+01 0.0000E+00 Evanescent
TM 2 2 5.1725E+09 0.0000E+00 1.1230E+03 1.0277E+02 0.0000E+00 Evanescent
EXCITATION BY IMPRESSED WAVEGUIDE MODE Name: Excitation index: 1 Frequency in Hz: FREQ = 1.64500E+09 Wavelength in m: LAMBDA = 1.82245E-01 Impressed mode: TE 1 0 Amplitude in A/m: 1.00000E+00 * PWFAKTOR (see below) Phase in degrees: 0.00 Transmitted power in W: 1.13772E+00 * PWFAKTOR^2 (see below) Attached to port label: Port
FEM Current Source
EXCITATION BY IMPRESSED CURRENT ELEMENT (FEM) Name: CurrentSource1 Excitation index: 1 Frequency in Hz: FREQ = 3.00000E+09 Wavelength in m: LAMBDA = 6.54669E-02 Amplitude in A: |I| = 1.00000E+00 Phase in degrees: ARG(I) = 0.00 Attached to port: FEM line port Start point of the port in m: x = 0.00000E+00, y = 6.50000E-03, z = -1.00000E-03 End point of the port in m: x = 0.00000E+00, y = 6.50000E-03, z = 0.00000E+00 Port length in m: 1.00000E-03
FEM Modal Source
MODE EXPANSION DATA OF A MODAL PORT
FEM modal port: Port1
Frequency: 3.00000E+09 Hz
Eigenvalues computed with ARPACK [Z]
Mode Propagation factor Description
counter real part imaginary part
1 0.00000E+00 9.59751E+01 Propagating (fundamental mode)
EXCITATION BY IMPRESSED MODAL PORT MODE Name: FEMModalSource1 Excitation index: 1 Frequency in Hz: FREQ = 3.00000E+09 Impressed mode: Fundamental Amplitude in V/m: 1.00000E+00 Phase in degrees: 0.00 Transmitted power in W: 5.00000E-01 Attached to port: Port1
Plane Wave Source
EXCITATION BY INCIDENT PLANE ELECTROMAGNETIC WAVE
Name:
Excitation index: 1
Frequency in Hz: FREQ = 1.49896E+07
Wavelength in m: LAMBDA = 2.00000E+01
Direction of incidence: THETA = -180.00 PHI = 0.00
Polarisation: LINEAR
Axial ratio: V = 0.0000
Polarisation angle: ETA = 0.00
Direction of propag.: BETA0X = 0.00000E+00
(unit vector) BETA0Y = 0.00000E+00
BETA0Z = 1.00000E+00
Wave number: BETA0 = ( 3.14159E-01 +j 0.00000E+00)
Phase reference point in m: x = 0.00000E+00, y = 0.00000E+00, z = 0.00000E+00
Field strength in V/m: |E0X| = 1.00000E+00 ARG(E0X) = 0.00
(Phase in degrees) |E0Y| = 0.00000E+00 ARG(E0Y) = 0.00
|E0Z| = 0.00000E+00 ARG(E0Z) = 0.00
The vector , whose components are given, is the vector which points in the direction of propagation. The vector represents the direction of the electric field.
Near Field Source
EXCITATION BY NEAR FIELD SOURCE
Aperture number: 1
Number of electric dipoles: 90 (of which 20 suppressed)
Number of magnetic dipoles: 90 (of which 32 suppressed)
Extent of the source: X = -5.83200E-02 ... 5.83200E-02 m
Y = -2.59200E-02 ... 2.59200E-02 m
Z = -2.56439E-01 ... -2.56439E-01 m
Impressed Radiation Pattern
EXCITATION BY A FAR FIELD POINT SOURCE
Excitation index: 1
Frequency in Hz: FREQ = 1.60000E+09
Wavelength in m: LAMBDA = 1.87370E-01
Max. field strength * dist. in V: 5.91419E+01 * PWFAKTOR (see below)
Radiated power in W: 1.12755E+00 * PWFAKTOR^2 (see below)
Directivity of the antenna in dB: 17.138
Distance for far field cond. in m: 1.96442E+00
Source position in m: x = 0.00000E+00, y = 0.00000E+00, z = 0.00000E+00
Number of grid points NTHETA = 37
NPHI = 73
Angular range THETA in degrees: 0.00 ... 180.00
PHI in degrees: 0.00 ... 360.00
Spherical Mode Source
For an impressed spherical mode source, the following information is written to the output:
EXCITATION BY AN IMPRESSED SPHERICAL MODE
Excitation index: 1
Frequency in Hz: FREQ = 6.25000E+09
Wavelength in m: LAMBDA = 4.79668E-02
Source position in m: x = 0.00000E+00, y = 0.00000E+00, z = 2.54000E-01
Rotation about the axes: X = -180.00
Y = 48.46
Z = 0.00
Number of modes: 880 (of which 38 suppressed)
Propagation direction: C = 4 (outwards)
mode indices coefficient in sqrt(Watt) rad. power(Watt)
J S M N magn. phase power
1 1 -1 1 2.54050E-05 -25.23 3.22706E-10
2 2 -1 1 4.50632E-05 1.04 1.01535E-09
3 1 0 1 5.41621E-07 40.48 1.46677E-13
Hertzian Dipoles
EXCITATION BY ELECTRIC DIPOLE
Excitation index: 1
Frequency in Hz: FREQ = 3.00000E+08
Wavelength in m: LAMBDA = 9.99308E-01
Amplitude in Am: |IL| = 1.00000E+00
Phase in degrees: ARG(IL) = 0.00
Dipole position in m: x = 0.00000E+00, y = 0.00000E+00, z = 0.00000E+00
Orientation of dipole: THETA = 0.00
PHI = 0.00
The above output is for an electric dipole. The magnetic dipole will have similar output.
