Batch Mode
Batch Mode
Flow simulator allows command line options to access various options of flow simulator. Here is the Flow Simulator Command list that user can access for various purposes.
| Flow Simulator - Console Command List | |
| FlowSimulator.exe -argument | Functionality |
| -help or -h | Display help menu for commands |
| -v | Flow Simulator Version |
| -open | Flow Simulator GUI (-open [myFile.flo]) |
| -ic5 | Initialize |
| -r2 | Run Solver |
| -fsave | Save Results to a separate folder “yes” |
| -o | Save File (-o myFile.flo) |
| -l | Load File (-l myFile.flo) |
| -i | Import File (-i myFile.out [myFile.flo]) |
| -e | Export File (-e myFile.flo [myFile.out]) |
| -mc1 file | File is the multicase import file to open |
| -mc2 # | Set multicase starting case to # |
| -mc3 # | Set multicase ending case to # |
| -mc4 file | File is the multicase prescript to open |
| -mc5 file | File is the multicase postscript to open |
| -mc6y | Set multicase initialization to “yes” |
| -mc6n | Set multicase initialization to “no” |
| -mc7a | Set multicase load option to “1st case only” |
| -mc7b | Set multicase load option to “every case” |
Examples
Processing Priorities: Load File > Import File > Initialize File > Export File > Save File > Run Solver
Example 1:
To load file then import file then save file commands are executed:
FlowSimulator.exe -l myFile.flo -o myFileSaved.flo -i myFile.out
Example 2:
To open Flow Simulator GUI from command line:
FlowSimulator.exe -v FlowSimulator.exe -h FlowSimulator.exe -help
Example 3:
To open GUI with a myFile.flo file or to open without a file.
FlowSimulator.exe -open
FlowSimulator.exe -open myFile.flo
Example 4:
To run Flow Simulator with multicase *.mcs file:
FlowSimulator.exe -l myFile.flo -mc1 my_import_file -mc2 1 -mc3 21 -mc6y
Example 5:
To load a myFile.flo, initialize it, and save as myFile.flo.
FlowSimulator.exe -l myFile.flo -ic5 -o myNewFile.flo
Example 6:
To load myFile.flo, import myFile.out into myFile.flo, and save file as myFileSavedflo.
FlowSimulator.exe -l myFile.flo -i myFile.out -o myFileSaved.flo
Example 7:
To load myFile.flo, run solver on this file.
FlowSimulator.exe -l myFile.flo -r2
Example 8:
To load myFile.flo, run solver on this file and save results to a separate folder.
FlowSimulator.exe -l myFile.flo -fsave -r2
