Flux2021.2 is available with new features, corrections and improvements. It is a completely independent version. It is installed
by default in its own directory. It can not be installed on top of Flux 2021 (overwrite installation is blocked).
Flux2021.1 is available with new features, corrections and improvements. It is a completely independent version. It is installed
Flux PEEC is a 3D modeling module dedicated to electrical interconnections of power electronics devices. It also
provides RLC extraction and generation of SPICE-like equivalent circuits.
Flux provides a unified Material Identification tool based on the Altair Compose environment allowing to run an identification
of the coefficients required to create material in Flux.
This documentation deals with the Jython script used in Flux and allows to understand the various structures of
entities and functions, and use it in user scripts for example.
A foil coil is a winding obtained from a thin, rectangular, metallic sheet folded in
a spiral-like shape, as shown in Figure 1. The sheet is covered by an insulating coating (varnish). This
kind of coil design is common in electromagnetic devices such as power transformers
and reactors.
The current density distribution in a foil-wound coil fed by a time-varying source
depends on skin and proximity effects. Since the foil is usually very thin and made
from a material with a high electrical conductivity, the skin effect along its
thickness is negligible (i.e., the current density in each turn results practically
uniform along a radial direction). On the other hand, the current density in each
foil turn may greatly vary along the axial direction of the coil as a function of
both position and frequency.
This anisotropic behavior is specific to foil coils and influences the Joule losses
developed in the bulk of the coil material. Thus, Flux now provides a new subtype of
the coil conductor region with losses and detailed geometric description that
implements a homogenization technique to represent this type of coil efficiently in
its 2D Steady State AC application. This technique is exclusive to foil coils and
differs from the approach used in the other subtypes of coil conductor regions with
losses and detailed geometric description representing stranded coils.
Using this new coil conductor region subtype spares the user from representing each
turn of the foil coil with an individual solid conductor region (linked to its
corresponding FE coupling component in a complicated electric circuit). While this
latter approach is also legitimate and rigorous, it is usually very time consuming
to set up in Flux due to the elaborate geometry and the refined mesh required.
Moreover, the solving time with the new foil-wound coil conductor region subtype is
significantly reduced when compared to the alternate solid conductor approach.
Example of application
The foil coil configuration shown in Figure 2 has been analyzed in the article Calculation of Current
Distribution and Optimum Dimensions of Foil-Wound Air-Cored Reactors by M.M.
El-Missiry (Proceedings of the Institution of Electrical Engineers, vol. 124,
no. 11,November 1977, DOI: 10.1049/piee.1977.0218 ). In that
work, the author presents a circuit-based, semi-analytical method to compute the
current density distribution and several other electromagnetic quantities of a foil
coil.
The coil in Figure 2
may be easily modeled in Flux 2D with the foil coil template available for coil
conductor regions with losses and detailed geometrical description. Figure 3 shows the results
obtained with an axisymmetric Steady State AC Magnetic application at 50 Hz and with
an additional horizontal symmetry (i.e., only one quarter of the foil coil is
represented). The development of a non-uniform current distribution pattern
characteristic to foil coils may be verified in the color plot available in that
figure.
A comparison between the current density results obtained with the approach
described in that article and the solution evaluated with Flux 2D is provided in
Figure 4. The graph in
this figure displays the real and imaginary parts of the current density phasor (in
RMS values) on a path from its upper extremity (0.0 p.u.) to its center (0.5 p.u.)
along one of the centermost turns of the coil (as depicted in Figure 3).
An additional comparison between measured lumped circuit parameters (provided
in El-Missiry's article) and their corresponding values computed with Flux 2D
(obtainable, for instance, with the help of I/O Parameters defined by formulas) is
available in Table 1.
Table 1. Comparison between resistance and reactance measurements and the results
yielded by Flux 2D for the Aluminum foil coil represented in Figure
2.
Lumped circuit parameter at 50 Hz
Measurement
Flux 2D
Deviation
Reactance
1.802 Ω
1.827 Ω
1.39%
Resistance
0.382 Ω
0.376 Ω
1.57%
The results from Figure 4 and from Table 1 show that the FEM solution evaluated with Flux 2D is in
excellent agreement with both measurements and other numerical techniques.
