Paths: definition (structure)
Definition
A path is defined by:
  • a name (and a comment)
  • a type
  • specific characteristics belonging to a type
  • a coordinate system for definition
  • attributes of color and visibility
Name
The name to identify the path is set by the user during the creation of this one.
A comment (optional) can be added to the name.
Types of path
The different types of paths and the characteristics useful for their description are presented in the table below.
Type Characteristics
path defined by two points
starting point (coordinates)
ending point (coordinates)
arc path defined by three points
starting point
(coordinates)
middle point
(coordinates)
ending point
(coordinates)
arc defined by center, radius and angles coordinate system for definition
center point
(coordinates)
radius
starting angle
ending angle
parametrized path coordinate system for definition
functions
(coordinates dependent on parameter)
parameter variation
(minimum and maximum)
It is not possible to modify a path.
