The Altair GUI Toolkit is a resource tool for coding Tcl/Tk dialogs. It contains documentation of the HyperWorks commands, demo pages that illustrate our Altair GUI standards, and sample code for creating those examples.
The Model Identification Tool, known as HyperWorks, is a profile in HyperGraph for fitting test data from frequency- and amplitude-dependent bushings to analytical models. The HyperWorks operates in conjunction with HyperGraph, MotionView and MotionSolve to provide you with a comprehensive solution for modeling and analysis.
HgTrans translates solver results files from their native file format to Altair Binary Format (ABF). This can be done using
the HgTrans GUI or via the HgTrans batch mode.
The HyperWorks Automation Toolkit (HWAT) is a collection of functions and widgets that allows an application to quickly assemble
HyperWorks automations with minimal effort and maximum portability.
Administrative tools to customize your Altair Simulation
installation.
Altair License Utility
The Altair License Utility is a tool allowing you to determine a host ID, check license usage, borrow licenses, and set up hosted Altair Units.
Altair Compute Console Altair Compute Console (ACC) is a utility that allows you to start different Altair Simulation Solvers.
Remote Job Submission
Remote Job Submission in Altair Compute Console (ACC) is implemented as an alternative to a local run.
AbaqusODB Upgrade AbaqusODB UpGrade is a HyperView tool, which upgrades ODB files created in Abaqus 2016 (or earlier) to Abaqus 2021.
HvTrans HvTrans is a result translator for HyperView that translates solver result files to .h3d files.
HyperWorks GUI Toolkit
HyperWorks Cleanup Utility
The HyperWorks Cleanup Utility is a script for Windows that removes any custom settings that you may have due to HyperWorks.
Register HVPcontrol
Register HVPcontrol registers the HVP ActiveX control for HyperView Player.
HgTrans HgTrans translates solver results files from their native file format to Altair Binary Format (ABF). This can be done using the HgTrans GUI or via the HgTrans batch mode.
The HyperWorks Automation Toolkit (HWAT) is a collection of functions and widgets that allows an application to quickly assemble HyperWorks automations with minimal effort and maximum portability.
H3D Validation Tools
The H3D Validation Tools available in HyperWorks are H3D Info and H3D Validate.
Uninstall
Use the Altair Simulation Products Uninstaller to remove all files from the installation directory.
