Sample configuration files and geometry input files are provided with the binary to test the proper system setting
and see if the simulation starts correctly on the system.
nanoFluidX prep, shortened as nFX[p], is an auxiliary executable for nanoFluidX intended to eliminate a number of potential user errors during the pre-processing phase.
nanoFluidX companion, also known as nFX[c], is a post-processing tool developed to accompany the nanoFluidX solver and allow for an easier execution of certain post-processing tasks.
nanoFluidX monitor, known as nFX[m], is a single file portable Python executable that is aimed for helping with monitoring a nanoFluidX simulation during runtime.
