| Note: | To accept selection(s), press Enter, click Yes or right-click the mouse button; or select Cancel. |
All the "uncreated spotwelds" can be created automatically:
| • | Open the menu, Connections > Spotweld > Automatic. |
| • | From the Menu Bar, select Connections > Spotweld > Create. |
Button |
Behavior |
pick parts on the graphic window (the parts become red). |
include parts by dragging a box in the graphic window:
include the parts selected in the tree. |
To create a spotweld with the same part twice, first select the part (it becomes red) and then, using the ALT key, select the same part once more (it becomes yellow).
Four options are available to set the position of the spotweld:
| 1. | Click |
| 2. | Set an element ID in the Shell Element Id field and click Ok. |
| 1. | Click |
| 2. | Click |
| 3. | Set a node ID in the Node Id field and click Ok. |
| 4. | Set the coordinates x, y, and z and click |
| 1. | Click |
| 2. | Enter the length between two spotwelds in the Pitch length field and click Ok. |
| 3. | Click |
| 4. | Click |
| 5. | Click |
| • | Select the Auto tab. |
| 1. | Enter or modify the Search gap value. |
| 2. | Click |
| 3. | Click |
In all cases, save the created spotweld:
| • | Click Save to save the created spotweld(s). |
If necessary, select another element, node, or line according to the active position setting mode.
| • | Click Cancel to cancel the spotweld creation. |
If necessary, set a position to create new spotweld(s) using elements, node, or line selection.
| • | Click Close to close the menu. |
