Volume Mesh Control Options
Check mesh quality using tools accessed from the context menu that opens when you right-click on a Volume Mesh folder in the Mesh Controls Browser.
- Check 2D Mesh
- Validate the input surface mesh before performing volume mesh generation using the Boundary Shell Checker tool.
- Solid Mesh Optimization
- Fix 3D elements in the following ways using the Solid Mesh
Optimization tool.
- Fix hexa and tetra element quality with respect to several element criteria.
- Fix second order element's maximum angle, and minimum and maximum length ratio and Jacobian.
