Manage Transformations with the Transformation Manager
Manage the definition of transformation applied on the nodes and elements in order to easily position the entity using a combination of scale, rotate, and translate and symmetry functions.
These operations are usually applied on standard parts such as dummies, barriers, and so on for positioning in different crash setups. Also they can be used for repositioning components with strain history between multiple steps of simulation.
Access the Transformation Manager by selecting from the menu bar.
- Transformation Definition
 - Lists the transformations defined in the model in a tree structure detailing the cross referencing between the entity and the transformation.
Toolbars
| Icon | Function |
                Activate the selected transformation. If none are selected, activate all the transformations defined. |
                Inactive the selected transformation. If none are selected, inactivate all the transformations defined. |
                Active or inactive state depending in its current state for the selected transformation. If none is selected, it is applied on all the transformations defined. |
                Switches to transformation – entity view |
                Switches to entity – transformation view |
Context Menu
A context menu is available for any selected item in the Transformation Manager tree. To view the context menu right-click on an entity folder, an individual entity, or in an empty space in the browser. Clicking in the empty space provides options applicable to all the entities in the transformation definition. The functions vary depending on whether it is performed on an entity in the transformation repository or in a transformation definition. There are also subtle differences in functions performed depending on the view.
| Item | Definition |
| Add entity | Allows you to edit the entity on which transformation is defined. Available only on entity. |
| Card edit | Opens the corresponding solver Card Image panel. Available on both entity and transformation. |
| Delete | Deletes the selected entity. Available on both entity and transformation. |
| Transform | Creates a new transformation and applies it on the selected entity. If transformation already exists for the entity, it appends to it. Available on the entity. |
| Rename | Renames the selected entity/ transformation. Available on both entity and transformation. |
| Show, Hide, Isolate, Show all, Review, Reset review: | Similar to Model Browser functions. Available for both transformation and entity. |
| Move UP | Swaps the ID of the selected transformation with the next smaller ID that is attached to the same entity. |
| Move up | Swaps the ID of the selected transformation with the next higher ID that is attached to the same entity. |
| Collapse All | Closes all of the folders in the tree structure, so that only the top-most level of items displays. |
| Expand All | Opens all of the folders in the entire tree structure, exposing every item nested at every level. |
| Item | Definition |
| Create new | Creates new transformation. |
| Add entity | Allows to add a new entity on to the selected transformation. If the entity is selected, you can edit the content. Available on both entity and transformation. |
| Transform | Appends the defined transformation on the selected transformation. Available only on the transformation. |
| Rename | Renames the selected entity. Available on both entity and transformation. |
| Show, Hide, Isolate, Show all, Review, Reset review | Similar to Model Browser functions. Available for both transformation and entity. |
| Move Up | Swaps the ID of the selected transformation with the next smaller ID that is attached to the same entity. |
| Move Down | Swaps the ID of the selected transformation with the next higher ID that is attached to the same entity. |
Transformation Repository
| Item | Definition |
| Transform | Creates new transformation on the selected entity. The transformation and the entity show up in the transformation definition folder. |
| Card Edit | Opens the corresponding solver Card Image panel. |
| Rename | Renames the selected entity. |
| Show, Hide, Isolate, Review, Reset review: | Similar to Model Browser functions. |
