Browsers supply a great deal of view-related functionality in HyperMesh by listing the parts of a model in a tabular and/or tree-based format, and providing controls inside the table
that allow you to alter the display of model parts.
Perform automatic checks on CAD models, and identify potential issues with geometry that may slow down the meshing
process using the Verification and Comparison tools.
Space frames are models that have a sparse distribution of elements, such as a car body. Space frame models can generally
have element counts in the hundreds of thousands, but their basic structure is rather simple.
Shell models are models that are made up primarily of shell elements, namely, quads, and trias. In general, a shell
model represents many parts, each with numerous features such as holes and edges, and connected together using 1D
elements such as bars and rigids.
Global handles are most effective when used to make general shape changes for a model, such as changing the basic
shape of a model, stretching parts of a model, or making changes that involve the movement of many local handles.
Solid models are models that are made up of solid elements, namely, tetras, pentas, and hexas. In general, a solid
model represents a single part with numerous features such as holes, edges, bosses, flanges and ribs.
You can change the shape of a model with local domains and handles.
Morphing can be accomplished using one or more of the following methods:
Moving the local handles
Changing a distance or angle
Changing the radius, curvature, or arc angle of an edge domain
Mapping nodes to a line, plane, surface, or mesh
Using section mapping, line and surface difference, and element offset
Using freehand morphing capabilities such as move nodes, record, and sculpting
You can move handles in the Morph panel, Move Handles subpanel using the following
options:
interactive
Move handles interactively by dragging the mouse across the screen. You select an
entity such as a vector, line, plane, surface, or domains, to orient the mouse
location in 3D space, and move a handle by clicking on it and dragging it to a new
location. Interactive morphing is most effective for visualizing how the mesh will
react when a handle is moved and for making approximate shape changes. If you want to
move a handle a specific distance or to a specific position, it is better to use a
non-interactive option.
translate
Translate handles along a vector or element normals.
rotate
Rotate handles about an axis.
move to XYZ
Position handles at specific XYZ locations or place them on lines, surfaces, or
another mesh.
move to node, move to point
Position handles at specific node or point locations, or place them on lines,
surfaces, or another mesh.
Figure 1. Morph by Translating Handles along Edge. By selecting the two handles along the edge of the flange and translating them along
a vector defined at the end of the section (green and blue nodes), the length of the
flange is reduced.
Figure 2. Morph by Translating Handles along Vector. By selecting the three handles and translating them along a vector defined at the
end of the section, the width of the channel is increased.
Figure 3. Morph by Translating Handles at Bottom of Part. By selecting the handles at the bottom of the part and translating them upwards, the
thickness of the lower section is reduced.
Figure 4. Morph by Translating Handles around Bolt Boss. By selecting all the handles around the bolt boss and translating them horizontally,
the position of the bolt boss is modified.
Figure 5. Morph by Rotating Handles at End of Section - Constant. By selecting all the handles at the end of the section and rotating them about a
point (violet node), the end angle of the section is modified.
Figure 6. Morph by Rotating Handles at Right End of Block - Constant. The right end of the block is given a constant rotation.
Figure 7. Morph by Rotating Handles for Entire Block - Linear. The entire block is given a linear rotation. Note how the magnitude of the twist
increases linearly with the distance from the base (purple) node.
When applying handle perturbations to your model, it is important to note that the nodes in
the model follow the movements of the handles according to the influence coefficients. This
concept comes into play when you are using the rotate function. After rotating handles you
may find areas in the model, particularly those defined by curved edges, that are not
rotated the same as the neighboring handles. This is because the nodes have followed the
handles instead of being rotated about the axis. To correct this situation, select the
true rotation checkbox. This will cause the nodes to be rotated as
well as the handles with the amount of rotation being equal to the influence coefficient.
Although it could be argued that true rotation is the "correct" way to morph via rotation of
the handles, not all morphing applications are best done using true rotation.
Figure 8. Morph by Rotation Handles - Normal. Although the highlighted handles are rotated, the circle at the center of the model
remains on the same plane as before.
Figure 9. Morph by Rotating Handles - True Rotation. During "true rotation" the nodes rotate along with the handles.
While morphing a model, the following message may be displayed: "Some handles selected are
dependent on others. Would you like to ignore dependencies for this operation?". This occurs
when both a dependent handle and the handle on which it is dependent are selected to be
morphed. If you click yes the given perturbation is applied to each
handle and the dependent handles are not given an additional perturbation inherited from
another handle. If you click no, the given perturbation and any
inherited perturbation is applied to each dependent node. For most cases you will want to
click yes.
The Morph panel, Alter Dimensions subpanel allows you to change one of the parameters in
the model, such as the distance between nodes, the angle between nodes, or the radius or
curvature of an edge domain. The basic concept is as follows:
Select two nodes (node a and node b).
Select handles corresponding to those nodes.
The handles selected are the ones that will move to make the distance between node a
and node b, or angle with a vertex selected, equal the specified value. You must select at
least one handle for each end and the handle may be coincident with one of the nodes. For
solid models, controlling a particular dimension often involves moving more than one handle
for each end.
Figure 10. Morph by Altering Dimensions using Channel's Bottom Width - Distance. By selecting the width of the bottom of the channel as the desired distance to alter
(green and blue nodes) and by selecting the handles on the left (highlighted) to follow
the green node and the handles on the right (shown as gray) to follow the blue node, the
width of the bottom of the channel can be changed from 60 to 30 with the rest of the
channel changing along with it.
Figure 11. Morph by Altering Dimensions using Block Thickness - Distance. By selecting the thickness of the block as the desired distance to alter (green and
blue nodes) and by selecting the handles on the radius (shown as gray) to follow the
green node and the handles on the back face (highlighted) to follow the blue node, the
thickness of the block between the radius and the back face is altered from 15 to 25 by
moving the entire back face.
Figure 12. Morph by Altering Dimensions using Angle of Channel's Left Side - Angle. By selecting the angle of the left side of the channel (green, blue, and red nodes)
and by selecting the handle at the bottom right of the channel (shown as gray) to follow
the green node and the handle at the red node (highlighted) to follow the red node, the
angle of the left side of the section is changed from 110 degrees to 90 degrees.
Figure 13. Morph by Altering Dimensions using Angle between Two Faces of Block - Angle. By selecting the angle between two faces of the block (green, blue, and red nodes)
and by selecting the handles at and directly below the green node (shown as gray) to
follow the green node and the handles at, near, and below the red node (highlighted) to
follow the red node, the angle is altered from 126 degrees to 90 degrees.
The radius, curvature, and arc angle options are used as follows. You select any number of
curved edge or 2D domains, select the center calculation and style
options, set the new radius, curvature multiplication, or arc angle factor for them, and
click morph. All the domains are changed simultaneously.
Note: The
curvature tool scales your radius by a factor rather than a set radius, so if you want to
change a radius from 5.0 to 8.0, you need to set the curve ratio to 1.6. The curvature
tool is intended for domains that do not have constant curvature. Making the bias factor
retroactive does not work for radius changes.
Figure 14. Morph by Altering Dimensions - Radius and Center. By selecting the edge domain around the edge of the hole, the radius is changed from
3 to 1.5.
Figure 15. Morph by Altering Dimensions - Radius and Fillet. By selecting the edge domain at the corner of the part and selecting the fillet
option, the radius is changed from 5 to 2.5 and kept in line with the edges at either
end.
Figure 16. Morph by Altering Dimensions - Radius and Hold Ends. By selecting the edge domain at the corner of the part and selecting the hold ends
option, the radius is changed from 5 to 10 with the ends held in place.
Figure 17. Morph by Altering Dimensions - Radius and Hold End. By selecting the edge domain at the corner of the part, selecting the hold end
option, and selecting a node at the end of the edge domain, the radius is changed from 5
to 8 while the held end remains in place.
Figure 18. Morph by Altering Dimensions - Radius and Fillet. By selecting all of the edge domains that form the fillet between the flat sections
and the round section and changing them simultaneously, the fillet is reduced from 20 to
8.
Figure 19. Morph by Altering Dimensions - Radius. The radius is changed in three different ways. At the top right, the hold center
option is used. At the lower left, the hold ends option is used. At the lower right, the
fillet option is used. In all cases, both the top and bottom edge domains were selected
as well as the 2D domain and the by normals option was used for center calculation. This
option will directly calculate the radii for the nodes on the 2D domain instead of
inferring them from the edge domains which makes this approach more accurate for 2D
domains as well as more reliable for non-uniform meshes.
Figure 20. Morph by Altering Dimensions - Arc Angle. The arc angle of the mesh is changed from 60 to 90 degrees using by axis (the
vertical axis and violet base node) to calculate the center of curvature.
Figure 21. Morph by Altering Dimensions - Arc Angle. The arc angle of the fillet is changed from 90 to 180 degrees using by normals to
Methods available for calculating the center of curvature for the selected domains
include:
by normals (Default)
Uses the element normals to approximate where the center of curvature is for each
node in the selected domains. This method is not always accurate, but often gives good
results for regular meshes.
by axis
you may select an axis which will serve as the center of curvature.
by line
You may select a line which will serve as the center of curvature.
by node
You may select a node which will serve as the center of curvature.
by edges
Uses the edge domains to calculate the center of curvature with the center lying in
the plane of the edge domains. The symmetry option refers to how the morphing of the
edge domains is applied to neighboring 2D domains. The auto-symmetry option was the
default for HyperMorph prior to version 8.0. In 8.0 you
may choose to turn off symmetry when using this option.
For auto-symmetry, the changes in the radii of the edge domains are applied to any 2D
domain, depending on the number of edge domains you change for the 2D domains. If you change
only one edge domain for a given 2D domain, the radius change will not be applied linearly
across the 2D domain. If you change the radii of two edges for any given 2D domain, either a
linear or planar temporary symmetry is created between the two edge domains for the 2D
domain that will apply radius changes more linearly across the 2D domain. This works best if
the mesh is regular. If you are changing only one edge for a 2D domain, you can increase the
bias factor of any handles on an edge domain to yield a more even distribution.
Mapping an edge domain to a line or a 2D mesh to a plane, surface, or mesh is done using
the Map to Geom panel. This option is very effective for fitting a mesh to new geometric
data. When mapping a domain to a geometric feature, all the nodes in neighboring domains are
stretched along with it, minimizing mesh distortion. You have several options for
determining how the nodes for the mapped domain are placed on the geometry. When mapping an
edge domain or node list the nodes can be moved normal to the line, along a vector to the
line, or distributed along the full length of the line. When mapping a 2D domain or
selection of nodes to a plane, surface, or mesh, the nodes can be moved normal to the
target, normal to the elements of the 2D domain or selected nodes, or along a vector. If you
wish to fit a mesh to a surface, there is no option to do this automatically, however, with
multiple mapping operations, or using the user control option you can
fit a 2D domain to a surface.
Furthermore, you have the option of creating a morph constraint between the nodes and the
map target automatically after mapping. This constraint will allow you to do further
morphing operations while maintaining the constrained nodes on the geometry.
The map to geom panel is also effective for solid model meshing. You can create a block of
solid elements roughly in the shape of the geometry that you are trying to mesh, and then
use map to surface to morph the faces of the block to the geometry.
Figure 22. Morph by Mapping to Line - Automap and Normal to Geom. The edge domain is mapped to a line by moving the nodes normal to the line.
Figure 23. Morph by Mapping to Line - Automap and Fit to Line. The edge domain is mapped to the line by fitting them along the line. Any
proportional spacing between the nodes will be maintained after mapping.
Figure 24. Morph by Mapping to Surface. By selecting the 2D domain on the top of the solid block to be mapped to the
surface, the entire solid block is morphed to match the surface.
Figure 25. Morph by Mapping to Surface. A rectangular C-section is mapped to a curved surface.
Figure 26. Morph by Mapping to Surface - User Control Approach. The surface and 2D domain are selected and the user control button is clicked. This
brings up a new panel which allows you to place handles or map edges prior to the
surface mapping operation. One by one each edge domain is placed on one of the lines
around the target surface using the fit to line option. This stretches the 2D domain to
match the surface more closely than before. When the map button is clicked, the domain
is the mapped to the surface, fitting it perfectly to the geometry.
