Mass Trimming Browser
Use the Mass Trimming tool to create, define and realize mass entities.
From the menu bar, click Tools > Mass Trimming.
Mass entities are used to define mass distribution. A mass entity stores information like the mass value, method of distribution, NSM, Point Mass, or Rigid mass with a mass center, and attached locations and realization types. These definitions are not associated with physical FE entities. If all of the FE entities in the model are deleted, the mass information will still be maintained. Mass entities can be saved in an HyperMesh binary file which can be imported into a new FE model and realized.
Mass Trimming Tool Interface
The Mass Trimming tool opens in the browser area.
The toolbar at the top of the Mass Trimming tool consists of tools used to create mass entities and control their display state.
The first pane displays all of the mass entities in your model, and their associated attributes. The second pane displays the Entity Editor, which can be used to define the attributes assigned to each mass entity.
Mass Trimming browser tools:
Tool Description
Creates an NSM mass.
Creates a Rigid mass.
Creates a point mass.
Interactively select any type of supported mass entity via the browser, or by selecting within the graphics area. The Selector can be used to find mass entities from the graphics area which will then be highlighted in the list. This is an efficient way of selecting multiple mass entities at once.
This tool can be used in conjunction with the Show, Hide, Isolate, and Isolate Only tools.
Show/hide selected mass entities.
Alternatively, click this mode on and then pick the desired mass from the graphics area; masses and any other entities determined by the view option toggle settings are hidden as you click on them.
Note: When used to select from the graphics area, this button only works on visible connectors.
Isolate/isolate only selected mass entities.
Alternatively, click this mode on and then pick the desired mass entity from the graphics area.
Opens the Perform FeAbsorb dialog, from which you can add (absorb) certain FE information into mass entities.
Finds and displays the realized FE for the selected mass entities.
Finds the entities attached to the selected mass entity. When this tool is active, all entities attached to the selected mass entity will be taken into account when a display change is performed.
Context Menu
In the Mass Trimming Browser, right-click to access the context menu. The options available in the menu are dependent upon whether you right-click on a mass entity, or in the white space of the browser.
Option Description
Create Create a mass entity.
Delete Delete the selected mass entity.
Rename Rename the selected mass entity.
Xref Entities Opens the References Browser and displays the relationship of the selected mass entities to other entities in the model in a hierarchical tree structure.
Realize Realize the selected mass entity.
Re-Realize Re-realize the selected mass entity.
Unrealize Unrealize the selected mass entity.
  If certain attachments cannot be made using the tolerance that is set, then a reconcile will accept the current attachments, ignore the failed ones, and change the status to green.
Show, Hide, Isolate, Isolate Only Control the display of the selected mass entities.
Review, Reset Review Review will show the mass entity highlighted with the rest of the displayed content in a grey transparent mode. Reset will restore the display.
Settings Apply a search order for failed mass attachment locations.
Only applicable for rigid masses with spider connections, and RBE3-RBE2 and RBE3-RBE2 links.
Supported Entities
Supported mass entities include:
NSM ()
A non-structural mass that can be distributed to elements, properties, and components, and defines/updates the required solver cards. A group entity is created for each mass entity. The group entity can be assigned a NSM1 or NSML1 card depending on the distribution method chosen. Only supported in OptiStruct and Nastran user profiles.
Rigid ()
A mass that takes the form of a mass element connected to nodes with rigid elements (Multiple RBE2, RBE3/RBE2, and so on).
Point ()
A single mass element that is created at each selected node. A value is computed based on the distribution method.
Mass Entity States
There are four states of mass entities. Each mass state is assigned a different color. Color coding provides an easier way to visualize and filter masses based on state.
unrealized ()
The initial definition of the mass entity after it is created. Unrealized masses are displayed yellow.
realized ()
The mass is considered realized only if weld creation at the mass was successful. Realized masses are displayed green.
modified ()
The mass is considered modified when one or more of its corresponding attributes have been edited in the Entity Editor. Modified masses are displayed blue.
failed ()
The mass is considered failed if the weld creation at the mass was not successful. Failed masses are displayed red.
Manage Mass Entities
Create, define and realize mass entities.
Create Mass Entities
Create Mass entities in the Mass Trimming Browser using one of the following methods:
  • In the browser, right-click and select Create from the context menu.
  • Click the Create Mass tool for the appropriate mass type on the toolbar.
Masses are organized by type in the browser.
Define Mass Entities
Define mass entities in the Entity Editor.
You can modify the distribution type, mass value, and total mass in the Mass Trimming Browser.
  1. In the Mass Trimming Browser, select the mass to define.
  2. In the Entity Editor, define the mass.
Mass Attributes
Supported attributes for Mass entities.
NSM Mass
Mass value
Mass value to be distributed.
NSM Distribution type
  • Total Mass. A NSML1 card is created with either an element set or a property set that is based on the NSM entity type definition.
  • Per unit area/length.
Property type
Type of elements or properties used to distribute the mass. Supported property types include PSHELL, PSHEAR, and PCOMP.
Location
  • If NSM entity type is Elements, than elements can be selected in the model and element set will be created for the NSM solver card.
  • If NSM entity type is Properties, than properties can be selected in the model and a property set will be created to realize the mass entity.
Reconnect rule
Rigid Mass
Calculate node
Calculates the mass location at the CG of the attachment points.
Mass value
Mass value to be put at the mass center.
Realization type
  • RBE2. The mass takes the form of a mass element connected to nodes with rigid elements (multiple RBE2).
  • RBE2 link. The mass takes the form of a mass element connected to nodes with a rigidlink element (single RBE2).
  • RBE3. The mass takes the form of a mass element connected to nodes with a RBE3 element.
  • RBE3-RBE2. The mass takes the form of a mass element connected to nodes with a RBE3 element connected to RBE2.
  • RBE3-RBE2 link. The mass takes the form of a mass element connected to nodes with a RBE3 element connected to RBE2 link.
Location
Position at which the mass is created. If the calculate node option is not selected, then a location for mass center will need to be selected.
Attachment point
To define the attachment points, nodes have to be selected in the model. Node selection is not used as is. A search is performed to see what is attached to the nodes.
  • If a node is selected on a hole, then the center of the hole will become the attachment location. If multiple nodes on a hole are selected, they will still treated as one attachment.
  • If a node is selected on a mesh, then the nodes of the attached elements (shell or solid) will be selected.
  • If two or more nodes are selected in close proximity and the attached elements are adjacent, then the entire patch will be selected.
  • If an independent node of a rigid is selected, then the independent node is selected for the attachment. The second leg is not created for two level rigid masses, such as RBE3-RBE2 or RBE3-RBE2 links. The first leg is terminated at the independent node.
  • If the free end of a CBUSH, with or without a tag, is attached to a rigid on the other end, then the second leg is not created and the rigid type mass is terminated at the first leg.
Attached Location Tolerance
Tolerance value used to search for nearby FE entities to attach.
Realization zone
Only available when the attachment is on a hole.
  • Inside. Use the nodes of the holes.
  • Outside. Use the node from the elements that form the hole, without the hole nodes.
  • Inside/outside. Use the nodes of the elements at the hole.
Mass Inertia
Rbe2/Rbe2 link
Realized FE in
  • Auto
  • Realized FE to current comp
  • Realized FE to selected comp
Figure 2. Nodes Selected for Attachment Points
Figure 3. Manual Mode for Single Level Rigid Creation. In this mode, only the selected nodes are used to define the rigid.
Figure 4. Automatic Mode for Single Level Rigid Creation. If the Manual option is not enabled in the Entity Editor, the nodes of adjacent elements will be used to define the rigid if the selected nodes are on a hole or are nodes on a mesh.
Figure 5. Two Level Rigid. In the case of a two level rigid, Automatic and Manual mode is not available. Instead, input nodes are processed. If input nodes are on a hole, then the nodes of the hole are used. If the realization is set to inside or inside/outside, then washer nodes are used. When the input node is an independent node or the free end of a cbush attached to a rigid, then the second level rigid will not be created. The RBE3 from the conm is terminated at these nodes.
Point Mass
Mass value
Mass value to be used for defining point masses.
Location
Position at which the mass is created. Can be nodes, elements, properties, or components. For elements, only shell elements are supported.
Distribution type
  • Apply to all nodes
  • Divide mass by nodes
  • Divide mass by area (Not available when Location is defined by Components or Properties)
  • Unit area distribution (Not available when Location is defined by Components or Properties)
Tolerance
Tolerance value used to search for nodes to create point mass elements. point mass on nodes, the tolerance value is used for a spherical search.
Threshold for Element Remapping(+-%)
When the old area and tolerance are used to search in the new mesh, the remapping may not always give 100% of the old area based on mesh size and pattern. A % value like +-10% will allow you to successfully remap and realize if the difference in area is within 10%.
Mass Inertia
Realized FE in
  • Auto
Limitations
  • For NSM and Point masses defined on elements, if the mass entity is in an unrealized state and partial elements are deleted, then upon rerealization, the status will be failed. If you translate the nodes of the elements and try to realize again, the graphics may be misleading because the failed locations might not reflect the translated location. However, re-realization with appropriate threshold values or a reconcile will work properly.
  • For NSM and Point masses defined on elements, if the mass entity is saved as an HyperMesh file and realized in a new design that has coincident elements in the same area, then both elements will be selected which will result in an increase of area of elements; hence the mass entity will fail, showing a new threshold value that is needed in order to realize properly. In such cases, the duplicate elements have to be deselected for those mass entities.
  • For Rigid masses in automatic mode, if a node on a hole is selected, then the nodes of the hole will be automatically selected. However, if the node is on the boundary of a mesh, then the nodes of the entire boundary will be selected even though it is not a hole. In automatic mode, it is advised that you do not select boundary nodes.
  • When performing FE-Absorb on Rigid masses, a rigid mass might be absorbed as a mass entity, and the realization might fail if the attachment point is not supported. For example, if the Rigid from a CONM2 mass is connected to a dependent node of another Rigid, FE-Absorb will absorb this as a mass entity. Re-realization will fail because only the independent node is supported as a valid node and not a dependent node.
  • For Rigid masses, Rigids will be absorbed during FE-Absorb as a Mass entity when they are connected to spring elements of any type, and a Rigid will be created during re-realization. If the FE model is deleted from the current session, realization will fail when you try to reapply the Trim mass to a new model, and a graphics message that reads “CBUSH node” will be displayed. At this point, you will only be able to reconnect to CBUSH spring elements.
Realize Mass Entities
In the Mass Trimming Browser, right-click on a mass entity and select Realize from the context menu.
Resolve Failed Connections
Execute the search order to resolve failed connections.
  1. In the browser, right-click on a Rigid mass and select Search Order from the context menu.
    When defining Rigid masses, the following attachments are defined:
    1. Node on a shell mesh
    2. Node of a hole on a shell mesh
    3. Independent node of a rigid
    4. Free end of a CBUSH with or without a tag that is attached to rigid on the other end
    Mass entities will fail during realization when:
    1. Current mesh is deleted
    2. A new model is imported that does not have a hole at the second location
    3. There is no independent node and free end of a CBUSH at #3 and #4
  2. You can execute a search order to find alternate connection methods at failed locations. The search order provides the following options which can be selected and ordered in the sequence it is desired.
    Figure 6.
    If you execute the search order, an alternate attachment method will be searched based on the tolerance in the sequence defined and establish connection at the failed locations. At this point, the new method will be saved for sub-sequent realizations. If within the tolerance, the search order does not find an alternate attachment method, then the status will remain failed. However, if after the search order is executed, and alternate attachment methods are established within the tolerance, then the status will turn to yellow and the mass entity can be realized.
  3. Click Apply.
Below is an example of reapplying Rigid Mass entities to a new mesh with mesh modifications, such that reapplying fails, but executing a search order finds alternate types of attachments.
  1. In the original mesh, the attachment type is a node on a shell mesh which finds nodes of adjacent elements to create the second level rigid.
    Figure 7.
  2. When the mesh is deleted and realized, the realization fails. The modeling window indicates what it is looking for at those attachment locations.
    Figure 8.
  3. When importing a new mesh, there is no shell mesh near the attachment within the tolerance at two locations; however, there is a hole and an independent node. After realizing, the mass fails at the two locations.
    Figure 9.
  4. Executing a search order with the following settings finds alternate attachment methods. The search order is set to first look for independent node. If no independent nodes are found it will then look for a shell mesh. The other options are not selected.
    Figure 10.
  5. The image below shows the alternate attachments that were found at those locations, which are realized.
    Figure 11.
  6. If the mesh is deleted and realized again, the new attachment method will be used for sub-sequent realizations. The original attachment method was node on a mesh at all three locations, but after executing the search order on the new mesh, the attachment methods change.
    Figure 12.
Perform FE Absorption
For FE models, use FE-Absorb to absorb the Trim Mass into the Mass entity.
During FE Absorption, you can only use realization types that are supported by the Mass Trimming tool. For second level rigids that cannot be absorbed completely, the independent node will be used as the attachment node.
Rigid Mass
  1. In the Mass Trimming Browser, click on the toolbar.
    The Perform FEAbsorb dialog opens.
  2. For Mass Type, select Rigid.
  3. Set the Entity filter.
    • Choose All to checks all elements to find FE.
    • Choose Select to open the entity selector, which you can use to select a portion of the model to find FE.
  4. For Realized FE in, select a component to organize realized FE.
    During absorption, no reorganizing is done based on this setting.
    Only available for realizations
    • Auto
    • Realized FE to original comp
  5. Click FeAbsorb.
    In the image below, the second level leg is attached to the node surface of the solid hole, which is not supported during the realization process. The second leg will instead be used to absorb the attachment to the independent node. A second level spider will not created during realization.
    Figure 13.
Point Mass
  2. For Mass Type, select Point.
    • Choose All to check all elements to find FE.
  4. Select an Entity creation rule.
    • Choose Based on magnitude to group all CONM's that are located directly on a mesh based on the magnitude, and creates one mass entity.
    • Choose Based on component to group all CONM's that are located directly on a mesh based on the magnitude and component the mesh is in, and creates one mass entity. If several meshed components have CONMs with the same magnitude, multiple mass entities will be created.
  5. Select an Apply rule.
    • Apply on all nodes
    • Total mass
  6. Click FeAbsorb.
    Only CONM2 masses will be absorbed since that is the only mass type supported during realization.
NSM Mass
  1. In the ,Mass Trimming Browser click on the toolbar.
  2. For Mass Type, select NSM.
  4. Select a Reconnect rule.
    This option is useful when the entities to be connected will be exchanged in a subsequent process. When rerealizing mass entities, HyperMesh looks for attachment entities based on the reconnect rule.
    • Choose None to not define a reconnect rule. If the attachment entity is not currently in the model, the mass with this reconnect rule will fail to realize. If no reconnect rule is defined for an attachment entity, the attachment will disappear from the mass when the attachment entity is deleted.
    • Choose Use id to reconnect using the IDs of the selected attachment entities. If the attachment entity is not currently in the model, the mass with this reconnect rule will search for entities with the same ID.
    • Choose Use name to reconnect using the names of the selected attachment entities. If the attachment entity is not currently in the model, the mass with this reconnect rule will search for entities with the same name.
  5. Click FeAbsorb.
