The tab area organizes browsers, Utility menus for the solver interfacing user profiles, and other functionality not shown in the panel area in different tabs.
Quickly find and open the tools, panels, and browsers that are available from the menu bar pull-downs or from the Utility Browser, as well as create solver cards.
Browsers supply a great deal of view-related functionality in HyperMesh by listing the parts of a model in a tabular and/or tree-based format, and providing controls inside the table
that allow you to alter the display of model parts.
Perform automatic checks on CAD models, and identify potential issues with geometry that may slow down the meshing
process using the Verification and Comparison tools.
You can only create solver cards with the Quick Access tool in the Radioss, OptiStruct, Abaqus, LS-DYNA, PAM-CRASH 2G and Permas user
profiles.
Enable the Quick Access tool by pressing Ctrl + F.
Once enabled, a search bar opens in the top,
right of the application.
Enter a search string.
Predicted results appear in a list.
Select a search result from the list, or press Enter to select the highlighted search
result.
Exit the Quick Access tool by pressing Esc or clicking anywhere outside of the tool.
Selecting a tool, panel, or browser from the list opens the
respective tool.
Selecting a solver card from the list creates a new card.
Tip: When
creating solver cards with the Quick Access tool, set the Model Browser as the current tab so that you can easily recognize
where newly created cards are being stored upon creation.
