DOE Variables
Common terminology in a DOE.
Variables
System parameters that can be changed to improve the system performance.
Reduced Variables
In DOE terminology, it is standard practice to work with reduced variables that have a range of -1 to 1 for each real variable. Reduced variables are associated to real variables with the following formula:
y = x − ( x max + x min ) 2 x max − x min 2
where x is the initial variable, and y is the reduced variable.
Levels
Values taken by y in the range [-1; +1]. The number of levels per variable to be considered depends on the level of non-linearity in the problem; for a linear model two levels are sufficient; for a quadratic model three levels are needed.
