Evaluation Parameters
Modify the run environment settings for the Evaluation tasks.
  1. From the Evaluation step, click the Evaluation Parameters tab.
  2. In the Value column, modify settings accordingly.
    Note: Review the Effectuation column to determine the scope at which each setting takes effect.
