Method of Feasible Directions (MFD)
The fundamental principle behind the Method of Feasible Directions is to move from one feasible design to an improved feasible design, therefore, the objective function must be reduced and the constraints at the new design point should not be violated.
Used for solving constrained optimization problems.
Usability Characteristics
  • A gradient-based method, which will most likely find the local optima.
  • May be efficient with a large number of constraints, but in general it is less accurate than Sequential Quadratic Programming and less efficient than Adaptive Response Surface Method.
  • One iteration of Method of Feasible Directions will require a number of simulations. The number of simulations required is a function of the number of input variables since finite difference method is used for gradient evaluation. As a result, it may be an expensive method for applications with a large number of input variables.
  • Method of Feasible Directions terminates if one of the conditions below are met:
    • One of the two convergence criterias are satisfied.
      • Absolute convergence (Absolute Convergence)
      • Relative convergence (Relative Convergence (%))
    • The maximum number of allowable iterations (Number of Evaluations) is reached.
    • An analysis fails and the “Terminate optimization” option is the default (On Failed Evaluation).
  • The number of evaluations in each iteration is automatically set and varies due to the finite difference calculations used in the sensitivity calculation. The number of evaluations in each iteration is dependent of the number of variables and the Sensitivity setting. The evaluations required for the finite difference are executed in parallel. The evaluations required for the line search are executed sequentially.
Figure 1. Method of Feasible Directions Process Phases
Settings
In the Specifications step, change method settings from the Settings and More tabs.
Note: For most applications the default settings work optimally, and you may only need to change the Maximum Iterations and On Failed Evaluation.
Table 1. Settings Tab
Parameter Default Range Description
Maximum Iterations 25 >0 Maximum number of iterations allowed.
Absolute Convergence 0.001 >0.0 Determines an absolute convergence tolerance, which is constant and equal to Absolute Convergence, times the initial objective function value. The design has converged when there are three consecutive designs for which the absolute change in the objective function is less than this tolerance. There also must not be any constraint whose allowable violation is exceeded in these three consecutive designs.
Note: A larger value allows for faster convergence, but worse results could be achieved.
{ c max i ≤ g max | f i − f i − 1 | < ε i = k , k − 1 , k − 2
where f is the objective value; k is the current iteration number; ε is the absolute convergence parameter; c max is the maximum constraint violation; g max is the allowable constraint violation.
Relative Convergence (%) 1.0 >0.0 The design has converged if the relative (percent) change in the objective function is less than this value for three consecutive designs. There also must not be any constraint whose allowable violation is exceeded in these three consecutive designs.
{ c max i ≤ g max { | f i − f i − 1 f i − 1 | < ε ,  if( | f i − 1 | >10 − 10 ) | f i − f i − 1 | < ε ,  if( | f i − 1 | ≤ 10 − 10 ) i = k , k − 1 , k − 2
where f is the objective value; k is the current iteration number; ε is the relative convergence parameter, c max is the maximum constraint violation; g max is the allowable constraint violation.
On Failed Evaluation Terminate optimization
  • Terminate optimization (default)
  • Ignore failed evaluations
Terminates with an error message when an analysis run fails.
Ignores the failed analysis run, and tries different step sizes to do line search.
Table 2. More Tab
Max Failed Evaluations 20,000 >=0 When On Failed Evaluations is set to Ignore failed evaluations (1), the optimizer will tolerate failures until this threshold for Max Failed Evaluations. This option is intended to allow the optimizer to stop after an excessive amount of failures.
Use Perturbation size No No or Yes Enables the use of Perturbation Size, otherwise an internal automatic perturbation size is set.
Perturbation Size 0.0001 >0.0
Defines the size of the finite difference perturbation.
For a variable x, with upper and lower bounds (xu and xl, respectively), the following logic is used to preserve reasonable perturbation sizes across a range of variables magnitudes:
  • If abs( x) >= 1.0 then perturbation = Perturbation Size * abs( x)
  • If (xu - xl) < 1.0 then perturbation = Perturbation Size * (xu – xl)
  • Otherwise perturbation = Perturbation Size
Use Inclusion Matrix No
  • No
  • With Initial
  • Without Initial
No
Ignores the Inclusion matrix
With Initial
Runs the initial point. The inclusion set and initial point are used to build the initial response surface.
Without Initial
Does not run the initial point. The inclusion set is used to build the initial response surface.
