Select a Numerical Method
Select a numerical method to use when evaluating the Sampling Fit.
  1. In the Specifications step, go to the Specifications tab.
  2. In the work area, Fit Type column, select a numerical method for each output response.
    By default, FAST is selected.
  3. Optional: In the Settings tab, change settings as needed.
  4. Click Apply.
    A run matrix is generated using the numerical method you selected.
Review and edit the run matrix in the Edit Data Summary dialog.
