ADM/ACF Entities
MotionSolve provides modeling elements that are not supported by the ADAMS solver. To enable you to use these elements with your ADAMS models, MotionSolve contains the following statements and commands in the ADAMS format:
  • CVSF
  • FLEX_BODY
  • H3D
  • PTSF
  • SFSF
  • TRANSIENT
Additionally, MotionSolve also provides keywords that let you modify the solver parameters from within an ACF file without having to edit the XML input deck.
