Strain Results Written in HyperView .h3d Format
1D Elements
ALL, DIRECT and TENSOR options
von Mises Strain
CELAS Strain
CROD Axial Strain
CBAR Longitudinal Strain SAC
CBAR Longitudinal Strain SAD
CBAR Longitudinal Strain SAE
CBAR Longitudinal Strain SAF
CBAR Longitudinal Strain SAMIN
CBAR Longitudinal Strain SAMAX
CBAR Longitudinal Strain SBC
CBAR Longitudinal Strain SBD
CBAR Longitudinal Strain SBE
CBAR Longitudinal Strain SBF
CBAR Longitudinal Strain SBMIN
CBAR Longitudinal Strain SBMAX
CWELD Axial Strain
CWELD Maximum Strain A
CWELD Minimum Strain A
CWELD Maximum Strain B
CWELD Minimum Strain B
CWELD Maximum Shear Strain
VON and PRINC options
von Mises Strain
1D Elements (CBAR/CBEAM via PBARL/PBEAML)
The following strain results are output for CBAR/CBEAM elements defined via PBARL/PBEAML property entries. The Result type: HyperView is CBAR/CBEAM Strains (<TYPE>), where the <TYPE> entry is based on the selected cross-section (TYPE/NAME field) on the PBARL/PBEAML entries. The element strain results can be reviewed for each cross-section type, corresponding evaluation point, at element ends (A or B). The maximum normal/shear/von Mises strains can also be reviewed.
CBAR/CBEAM Strains (<Type>)
<Strain Result Output> <evaluation point> (A/B)
<Type>- BAR, BOX, BOX1, CHAN, CHAN1, CHAN2, CROSS, H, HAT, I, I1, ROD, T, T1, T2, TUBE, Z
<Strain Result Output>- Normal, shear, and von Mises
<evaluation point>- Evaluation point of the element
Examples
CBAR/CBEAM Strains(BAR)
Normal S1N(A)
Normal S1N(B)
Shear S4S(A)
Shear S4S(B)
von Mises S8V(A)
von Mises S8V(B)
Normal S3N(B)- Normal strain at the 3rd evaluation point of the beam element (end B)
Shear S6S(A)- Shear strain at the 6th evaluation point of the beam element (end A)
von Mises S5V(B)- von Mises strain at the 5th evaluation point of the beam element (end B)
Review evaluation points via: DRESP1 - Static Strain Item Codes for Bar Elements using PBARL, PBEAML Properties
The von Mises strains for all CBEAM/CBAR elements with PBARL/PBEAML properties at the same time can be output using the Result type: CBAR/CBEAM von Mises Strains.
CBAR/CBEAM vonMises Strains
<Strain Result Output>- von Mises
2D Elements
ALL and TENSOR Options
Results are calculated by HyperView.
DIRECT Option
von Mises Strain
Maximum Principal Strain
von Mises Strain (Z1)
von Mises Strain (Z2)
von Mises Strain (mid)
P1 (major) Strain (Z1)
P1 (major) Strain (Z2)
P1 (major) Strain (mid)
P3 (minor) Strain (Z1)
P3 (minor) Strain (Z2)
P3 (minor) Strain (mid)
Normal X Strain (Z1)
Normal X Strain (Z2)
Normal X Strain (mid)
Normal Y Strain (Z1)
Normal Y Strain (Z2)
Normal Y Strain (mid)
Shear XY Strain (Z1)
Shear XY Strain (Z2)
Shear XY Strain (mid)
Principal Strain Angle (Z1)
Principal Strain Angle (Z2)
Principal Strain Angle (mid)
VON Option
von Mises Strain - This is equal to max[Von Mises Strain (Z1), Von Mises Strain (Z2)]
PRINC Option
von Mises Strain
3D Elements
DIRECT Option
von Mises Strain
Signed von Mises Strain
P1 (major) Strain (solid)
P2 (mid) Strain (solid)
P3 (minor) Strain (solid)
Normal X Strain (solid)
Normal Y Strain (solid)
Normal Z Strain (solid)
Shear XY Strain (solid)
Shear YZ Strain (solid)
Shear XZ Strain (solid)
VON Option
von Mises Strain
PRINC Option
von Mises Strain
- In the TENSOR mode, pass tensor components to HyperView which then calculates derived results on-the-fly.
- For frequency response loadcases, only the TENSOR mode is available.
