Capabilities
The analysis capabilities of Radioss are comparable to those of other standard finite element and multibody dynamics solvers.
Radioss can be used to analyze a wide variety of design problems in which the structural and system behavior can be simulated using finite element and multibody dynamics analysis.
- Full vehicle crash analysis
- Vehicle occupant safety analysis
- Finite Volume (FVM) airbag simulation
- Consumer products drop tests
- Quasi-static nonlinear simulations such as roof crush or rollover protection structure (ROPS)
- Advanced multiphysics simulation using Euler, Arbitrary Lagrangian Eulerian (ALE) and Smoothed-Particle Hydrodynamics (SPH)
- Fluid-structure interaction, such as airplane ditching
