Domain
Define the solid and fluid domains for the CFD simulation.
Note: If you only need to analyze the fluid part without
considering the surrounding geometry, then you can skip defining the solid domain,
and go directly to defining the fluid domain. The solver will treat everything that
doesn't have a boundary condition as in contact with a solid part.
