Drilling into Visualizations
Visualizations themselves can be used to drill into lower or upper details by selecting items, and right-clicking to display the context menu with three options:
q Drill Down – Drills down to the lower level of the selected value.
NOTE |
Drilling without filter (or soft drill) is turned on for all aggregates that refer to: · Nodes above the node like the parent or root · Siblings of the node Applicable to the following aggregates in the Aggregate drop-down list: · Sibling Rank · Percent of Total · Percent of Total Reference · Percent of Parent · Percent of Parent Reference · Percent of Total Change · Cumulative Sum · Cumulative Sum By Max
q Drill Up – Enabled when the lower level of the selected item is displayed. Click to drill to the upper level.
q Drill to Top – Drills to the top level of the selected value.
Drilling into visualizations can also be done by double-clicking on a value. Refer to Double Click Mode Options for more information.
