Creating Data Extract from Elasticsearch 7.x
The Elasticsearch 7.x connector allows you to connect and access data from an Elasticsearch cluster using Java High Level REST Client.
NOTE |
Similar to Elasticsearch 6.x connector but uses Java High Level REST Client.
1. On the New Data Extract page, select Elasticsearch 7.x in the Connector drop-down list.
2. Follow steps 3 to 6 in Elasticsearch 7.x to define the connector settings.
3. Click to save and display the details
of the data extract.
4. Click then
to display the data preview.
