Altair® Panopticon
Creating Density Plots in the Numeric Combination Graph
Sample data used in this section.
Category
x_var
A
1
A
1
A
1
A
2
A
3
A
3
A
4
A
4
A
4
A
4
B
1
B
2
B
2
B
2
B
2
B
3
B
3
B
3
B
4
B
4
A density plot describes the frequency or count of observations in data for each value along the x-axis. For a data set with a number of X-variable observation and two or more categories in the data, you create a density plot in the following way:
q  Put the Category text column on Items, the x-variable on X and the x-variable also on Visuals.
 Create a Numeric Bucket column of typ Id, based on the x-variable column (named idX) and add it to Items, as the top level.
q  On the Visuals x-variable column, switch off Single Series, and set Count as aggregation method.
q  On the X-axis x-variable columns, set Mean as aggregation method
q  Optionally, put the category column on Color, and select the category coloring for the Visuals column. Also select Smooth as line interpolation, and switch on Shade Area Below Line.
