Create Task to Extract Data
Tasks can be created to reload workbook or global extracts.
1. On the New Task pane, enter the Name of
the task and click . Ensure the name is unique.
2. Tap the Activated slider to turn it on.
3. Select the Trigger. You can either select:
· Period then enter the Interval (in seconds), or
· CRON then enter the CRON Expression
4. Select the task Type: Extract Data.
5. Enter the Description of the task.
6. Select the data extract to be scheduled in the Extract Name drop-down list box. The list is taken from the data extracts list on the Extracts tab.
7. Click .
Click to go back to the
Tasks pane. The new task is added in the list.
