Publishing a Workbook Folder to Panopticon Real Time
Publishes a workbook folder to Panopticon Real Time.
Option |
Description |
-tf, --targetFolder |
The target folder to which workbooks will be published. Use -r to publish all workbooks to the ROOT folder. This is only applicable with -wf Syntax example: java -jar pcli.jar publish -u "http://username:password@host:port/app_name/" -wf "folder containing workbooks"-tf "server folder name" -r |
-r, --root |
Publish workbooks to the ROOT folder. This is only applicable with -wf Syntax example: java -jar pcli.jar publish -u "http://username:password@host:port/app_name/" -wf "folder containing workbooks"-tf "server folder name" -r "default or root folder" |
-u, --url |
URL to Panopticon Real Time, syntax: java -jar pcli.jar publish -w "workbook" -u "http://username:password@host:port/app_name/" |
-wf, --workbookFolder |
The workbook folder from which workbooks will be picked to publish. Use -w to publish single workbook. Syntax example: java -jar pcli.jar publish -u "http://username:password@host:port/app_name/" -wf "folder containing workbooks"-tf "server folder name" -r |
Command example: java -cp pcli.jar publish "http://username:password123@localhost:8080/panopticon" -wf "C:\Serverdata\Data" -tf "c:\Streamsdata\Data" -r
