Special Symbols to Pass Parameter Values Into the HTML5 Client
When trying to pass parameters to the new HTML5 Client, you need to use URL-encoded characters.
For example, for {“Type”:[Soft/Drinks”]} to work, it should be changed to {“Type”:[Soft%252FDrinks”]}
Here is a list of double-encoded values you can use to replace their corresponding character.
Character |
Double Encode Value |
“%253C” |
“%252F” |
“%253E” |
