Using the Database Connector
For any database that you use with Panopticon Designer (Desktop) and Panopticon Visualization Server, it is necessary that there are drivers available that let you connect both from a .NET application like Panopticon Designer (Desktop), and from a Java application like Panopticon Visualization Server:
You would need to install the JDBC driver for the database on the system running Panopticon Visualization Server.
