Other Scheduler Tasks Operations
On the Scheduler tab of the System Settings page, you can also perform the following:
q Sort asks
A task displays the following columns: Name, Activated, Type, Trigger, Last Updated By, Created, and Last Run.
Modify the sorting of the list by clicking the or button of any of these columns. The icon beside the column that was used for the sorting will indicate if it was in an ascending or descending order.
q Manually run tasks
Instead of waiting for the set Period interval or CRON Expression, you can manually execute the task by clicking . A confirmation message displays.
Click .
q Modify tasks
q Delete tasks
Click of a task. A confirmation message displays.
Click .
