Building the Expression
To build the expression, you can either:
q manually enter into Expression text box
Take note that the column name is case sensitive.
A validation error displays with a suggestion to help build the expression.
Examples:
Click the link (e.g., [Mcap(USD)] to apply the correct entry.
Complete the expression as necessary.
q use the Expression Builder
